ผู้เขียน หัวข้อ: Import-Export N-Methylpyrrolidone, Methylpyrrolidone production, NMP factory  (อ่าน 88 ครั้ง)
  • กระทู้: 3788
« เมื่อ: 19 เมษายน 2568, เวลา 23:39:22 น. »
Import N-Methylpyrrolidone, Export N-Methylpyrrolidone,
Export Methylpyrrolidone , Produce Methylpyrrolidone,
NMP Wholesale Price, Produce NMP Factory Price, Export NMP Wholesale Price,
Produce NMP Factory Price, Distribute NMP Cheap Price,
Distribute N-Methylpyrrolidone NMP Factory, Methylpyrrolidone Company,
NMP Company, Import NMP, Import-Export N-Methylpyrrolidone,
Methyl Pyrrolidone, NMP, NMP, Methyl Pyrrolidone N-Methylpyrrolidone,
Non Toxic Solvent
NMP 2025 by PKSN 19-04-2025
TPCC PKSN NMP THAILAND
You can inquire about product information,
request for trial samples and order products at
Thai Poly Chemicals Company Limited (Solvent)
Methyl Pyrrolidone, NMP, N -Methylpyrrolidone,
Non Toxic Solvent Methyl Pyrrolidone production, Methyl Pyrrolidone distribution,
Methyl Pyrrolidone import, Methyl Pyrrolidone export,
Methyl Pyrrolidone production , Methyl Pyrrolidone distribution,
NMP production, NMP distribution, NMP import, NMP export
Product Name: N METHYL PYRROLIDONE
Chemical Family: Cyclic Amide
CAS Number: 872-50-4
Chemical formula: C5H9NO
Chemical Name: N-Methyl-2-pyrrolidinone
Synonyms: 2-Pyrrolidinone, 1-methyl-,
N-Methyl-2-pyrrolidinone, NMP
NMP APPLICATIONS
Electronics, NMP has been used in the electronics industry for many years as a photoresist stripper. Now, with the phase out of CFC’s, NMP has gained widespread acceptance as a solvent in other electronic applications including semi-aqueous de-fluxing, degreasing, and coatings (polyamide, epoxy and polyurethane).
Graffiti Removers,
NMP-based graffiti removers combine high performance and biodegradability with low volatility and low flammability. NMP can be blended with glycol ethers or acetates such as Glycol Ether PMA, PEA, and DPMA; they are cost effective and improve performance on surfaces defaced by lipstick and crayon graffiti.
Agricultural, the agricultural chemical industry takes advantage of NMP’s solvency and handling properties in agricultural formulations.
Consumer and Industrial Cleaners, NMP is an effective stripping agent used in floor stripping, oven cleaners, graffiti removers, and paint strippers. Due to its high solvency and low volatility, it is used in automotive and industrial cleaners with solvents such as hydrocarbons, terpenes, propylene carbonate and P-Series glycol ethers.
Coatings Solvent, NMP is a powerful solvent for most commercial resins. Due to its high boiling point and excellent solvent power, NMP extends and improves the properties of high temperature bake coatings. For instance, high solid binders are more easily obtained with NMP as the solvent. Quite often, baked finishes yield coatings with outstanding mechanical and dielectric properties. NMP also aids rheological control: better flow and leveling -less cratering and pin holing. For these reasons, NMP has been shown to be highly effective in wire coating and other high temperature coating applications. NMP is also the preferred solvent for urethane dispersions and is an excellent coalescent for acrylic and styrene acrylic latexes.
Petrochemical Processing, NMP has been shown to have a selective affinity for unsaturated hydrocarbons, aromatics and sulfur-bearing gases. Due to its relative non-reactivity and high solvency, NMP finds wide applicability as an extraction solvent in lube oil processing as well as in natural and synthetic gas purification's.
Miscellaneous Solvent Applications, the excellent thermal and chemical stability of NMP enhances its utility as a solvent or co-solvent in many synthetic reaction systems. NMP shows selective affinity for unsaturated hydrocarbons, aromatics, and sulfur compounds. NMP can serve as a co-solvent with water, aromatic, chlorinated hydrocarbons, alcohols, glycol ethers, and ketones, etc.
เอ็น-เมทิลไพร์โรลิโดน หรือ เอ็นเอ็มพี (NMP)
เป็นของเหลวไม่มีสี มีจุดเดือดสูง, มีความเป็น solvent strength สูง, อัตราการระเหยตัวต่ำ, มีความเป็นพิษต่ำมาก สามารถย่อยสลายได้โดยธรรมชาติ และเป็นมิตรกับสิ่งแวดล้อม. NMP เป็นตัวทำละลายทางเลือกใหม่ที่เป็นมิตรกับสิ่งแวดล้อม และเป็นตัวทดแทน เมทิลีนคลอไรด์ (MC) และ Methyl Ethyl Ketone (MEK) ซึ่งเป็นสารก่อมะเร็ง. NMP สามารถเป็น Co-Solvent โดยผสมเข้ากันได้กับน้ำ รวมถึงสารทำละลายอินทรีย์อื่น ๆ เช่น แอลกอฮอร์, ไกลคอลอีเธอร์, คีโตน, อะโรเมติคส์, Chlorinated hydrocarbons เป็นต้น
N-Methylpyrrolidone (NMP) is the lactam of 4-methylaminobutyric acid and a very weak base. NMP is a chemically stable and powerful polar solvent. These characteristics are highly useful in a variety of chemical reactions where an inert medium is of concern. Despite the stability of NMP, it can also play an active role in certain reactions: hydrolysis, oxidation, condensation, conversion with chlorinating agents, polymerization and o-alkylation, and related reactions.
N-Methylpyrrolidone is a colorless to slightly yellow liquid with a faint amine odor. It is miscible in water and conventional organic solvents. NMP are high boiling point, high solvent strength, low volatility, less toxicity, biodegradable and more environment friendly. NMP can serve as a co-solvent with water, alcohols, glycol ethers, ketones, and aromatic/chlorinated hydrocarbons.
Solvent products, Solvents, Solvents that Thai Polychemical Co., Ltd. distributes include ACETATE Butyl Acetate , BA Cellosolve Acetate , CA Ethyl Acetate, EA N-Propyl Acetate, NPAC ALCOHOL Benzyl Alcohol Cetyl Alcohol , Hexadecanol-1 Cetyl Stearyl Alcohol, Fatty Alcohol Cetyl Stearyl Alcohol Ethyl Alcohol , Ethanol Ethyl Alcohol, Ethanol Isobutyl Alcohol, Iso -Butanol Isopropyl Alcohol , Isopropanol, IPA Methyl Alcohol , Methanol Methanol n-Butyl Alcohol, n-Butanol Butyl Alcohol Butanol Stearyl Alcohol , Octadecanol-1 stearyl alcohol ETHANOLAMINE Ethanolamine Diethanolamine , DEA Diethylene Triamine , DETA Monoethanolamine, MEA Triethanolamine, TEA Triethylene Triamine, TETA Triisopropanolamine 85%, TIPA Triisopropanolamine TIPA ETHYLENE GLYCOL Ethylene glycol Diethylene glycol , DEG Monoethylene glycol , MEG Monoethylene glycol MEG Polyether glycol Polyethylene glycol, PEG Triethylene glycol , TEG PEG 200, 300 PEG200 PEG300 PEG 400, 600 PEG400 PEG600 PEG 1000 , 4000 PEG1000 PEG4000 PEG 6000 , 8000 PEG6000 PEG8000 ISOCYANATE Diphenylmethane Diisocyanate MDI, Methylene Diisocyanate Polyester Resin, Unsaturated Polyester TDI, Toluene Diisocyanate OIL SOLVENT Acetone Acrylic Binder, Acrylic Emulsion Alcohol Ethoxylate , AEO, 3,5,7,9 mole Alcohol Ethoxylate Base Oil 150SN, 500SN, 150BS Base Oil Base Oil Butyl Acetate, BA Butyl Acetate BA Butyl Carbitol Butyl Cellosolve Butyl Diglycol, BDG Butyl Diglycol BDG Castor Oil 36 Mole Ethoxylate Castor Oil Castor Oil Cellosolve Acetate, CA Cellosolve Acetate CA Cyclohexanone , CYC Cyclohexyl Ketone Cyclohexyl KetoneDiacetone Alcohol, DAA Dichloromethane , DCM Dimethylformamide, DMF Dimethyl Ketone , DMK Dimethyl Sulfoxide, DMSO Emulsifier Ethyl Acetate, EA Ethylene Glycol Monobutyl Ether Ethylene Glycol Monobutyl Ether Glycerine USP, Glycerol USP Glycerin Glycerol USP Glycol, Glycol Ether Glycol Glycol Ether Hexylene Glycol , HGL Hexylene Glycol HGL Hydraulic Fluid , Hydraulic Oil Ketohexamethylene Ketohexamethylene Lecithin (Soy Lecithin) Lecithin Lecithin Methylene Bichloride, MBC Methylene Chloride, MC Methylene Dichloride, MDC Methylene Dichloride, MDC Methyl Ethyl Ketone , MEK Methyl Isobutyl Ketone , MIBK Methyl Isobutyl Ketone, MIBK N-Methylpyrrolidone, NMP N-methylpyrrolidone NMP Nonylphenol Ethoxylate NP4, 6, 9, 10, 15 Nonylphenol Ethoxylate NP N -Propyl Acetate , NPAC N-Propyl Acetate NPAC Paraffin Oil, Liquid paraffin Paraffin oil Liquid paraffin Perchloroethylene , PCE Perchloroethylene PCE Pimelic Ketone Polybutene , PB 400, 950, 1300, 1400, 2400 Polybutene PB Polyoxyethylene Castor Oil Polyquaternium-7, 10 Polysorbate 20, 60, 80 (Tween 20, 60, 80) Polysorbate Propylene Carbonate Propylene Carbonate PC Propylene Glycol Mono Methyl Ether, PM Pure Acrylic Rubber Oil , Rubber Process Oil, Rubflex Rubber Process Oil Silicone Fluid , Silicone Oil Silicone Fluid Specialty Solvent , Please Contact TPCC Specialty Solvent, Please Contact TPCC Surfactant , N70 Surfactant Surfactant Tergitol 26L-3, 5, 7, 9 Tergitol 26L NP4, NP6, NP9, NP10 Tergitol NP Triacetin (PALMESTER) Triacetin Palm Ester Trichloroethylene, TCE Trichloroethylene TCE Tetrachloroethylene Tetrachloroethylene White Oil, White Mineral Oil White Oil White Mineral Oil MONOMER Butyl Acrylate Monomer, BAM Butyl Acrylate Monomer, BAM Methyl Methacrylate Monomer , MMA Styrene Monomer , SM Vinyl Acrylate Monomer, VAM PLASTICIZER Plasticize
Chlorinated Paraffin, CPW Chlorinated Paraffin, Plas Oil Dibutyl Phthalate, DBP Di -2-ethylhexyl-Adipate, DEHA Di- 2-ethylhexyl-Phthalate, DEHP Di- isononyl Phthalate, DINP Dioctyl Adipate, DOA Dioctyl Phthalate, DOP Dioctyl Terephthalate, DOTP Epoxidized Soybean Oil, EPO Epoxidized Soya Bean Oil , ESBO Epoxidized Soya Bean Oil ESBO Non-Phthalate Plasticizer Phthalate Free Plasticizer Trioctyl Trimellitate, TOTM PROPYLENE GLYCOL Propylene Glycol, DPG Dipropylene Glycol, DPG Hexylene Glycol, HGL Monopropylene Glycol, MPG Monopropylene Glycol , MPG Polypropylene Glycol, PPG Propylene Glycol EP , MPG-EP Propylene Glycol EP Grade PG EP Grade Propylene Glycol USP, MPG-USP Propylene Glycol USP Grade PG USP Grade
SPECIALTY SOLVENT Other special solvents
Please Directly Contact Technical Sales (Oil & Solvent Division)
Thai Poly Chemicals Company Limited BY PKSN NMP TPCC 2025
TAGS: Methylpyrrolidone production, NMP factory,
Methyl Pyrrolidone, NMP, N-Methylpyrrolidone,
Non Toxic Solvent N-Methylpyrrolidone Factory,
Buy N-Methylpyrrolidone Wholesale Price, Methylpyrrolidone Shop ,
Methylpyrrolidone Distributor Cheapest price, NMP production wholesale price,
NMP sale factory price, NMP distribution wholesale price,
NMP manufacturer factory price, NMP distribution cheap price,
N-methylpyrrolidone distribution wholesale NMP, Methylpyrrolidone wholesale shop,
NMP company, NMP distribution factory cheap price
  • กระทู้: 3788
Re: Import-Export N-Methylpyrrolidone, Methylpyrrolidone production, NMP factory
« ตอบกลับ #1 เมื่อ: 21 เมษายน 2568, เวลา 17:09:53 น. »
  • กระทู้: 3788
« ตอบกลับ #2 เมื่อ: 22 เมษายน 2568, เวลา 17:32:05 น. »
  • กระทู้: 3788
« ตอบกลับ #3 เมื่อ: 23 เมษายน 2568, เวลา 21:40:12 น. »
  • กระทู้: 3788
« ตอบกลับ #4 เมื่อ: เมื่อวานนี้ เวลา 15:52:17 »
